Has anyone had these errors in an IRC5 before?
  • DenisFR
    DenisFR ✭✭✭
    Did you change IP configuration?
  • No. The robot had been sitting idle for a day before this happened.
  • DenisFR
    DenisFR ✭✭✭
    Can you check all RJ45 cables?
    Are you using SafeMove2 card?
    Is your PLC connected?
  • Hi Denis. I am using SafeMove 2. I have a Siemens PLC connected to the IRC5 so I can communicate ProfiSafe signals. I have separated my ethernet cables from all the other cables as my first attempt to solve the problem. I plan to replace the Ethernet cables as the second attempt if the problem persists.
