Has anyone had these errors in an IRC5 before?
PTB
Hello,Did you change IP configuration?☑️2024 - RobotStudio® User Group0
No. The robot had been sitting idle for a day before this happened.0
Can you check all RJ45 cables?Are you using SafeMove2 card?Is your PLC connected?☑️2024 - RobotStudio® User Group0
Hi Denis. I am using SafeMove 2. I have a Siemens PLC connected to the IRC5 so I can communicate ProfiSafe signals. I have separated my ethernet cables from all the other cables as my first attempt to solve the problem. I plan to replace the Ethernet cables as the second attempt if the problem persists.0
- 348 IRC5
- 846 RAPID Programming
- 21 AppStudio
