xbox controller inhibition
jhip
Hi everybody
we develop an EGM guidance app connected to a XBOX controller
BUT in robotstudio, the XBOX controller is used too ! (for move and rotate the station)
Our question : can we inhibit the XBOX controller action on robotstudio ?
Hi !
I guess you found a way to solve your problem since then, but (in case) I solved it by removing the "Positioner_RPK" folder from "C:\ProgramData\ABB Industrial IT\Robotics IT\DistributionPackages\ABB.RobotWare-6.06.1025\RobotPackages"
Good luck with you Xbox controller, it really sounds great !
