MoveAbsJ with the \Inpos argument
Hey, I have multiple robots who's sharing the same zone. Since they do not have the world zones option my code looks as follow
MoveAbsJ Startpos,vmax,z20,tRob_4_Vevhusgrip\WObj:=wobj0;
        Reset OUT_bInSharedZone;
        Set 1_Ready;
        WaitUntil TestDI(2_Ready);
        Reset 1_Ready;
Since I want to keep a nice flow I don't want to use my MoveAbsJ as a stop-point, but this will as you know move the program pointer further down the code. I've tried the WaitRob \inpos, but this works the same as if I have a fine point.
I've read something about the \inpos argument in the MoveAbsJ instruction, but how does this work exactly? Does it make sure the PP won't move until the robot is within the specified zone?
Thanks!
  • soup
    soup ✭✭✭
    I forget if it's an option you have to buy or not, but could TriggIO work?
  • lemster68
    lemster68 ✭✭✭
    1.  Is this a multimove system?  2.  Is a PLC controlling the robots?
    Lee Justice
    Sadly there is no TriggAbsJ...
    1. No. 2. Yes!
  • soup
    soup ✭✭✭
    That's too bad.
    Maybe a WZHomeJointDef around the target to get I/O to trigger a little early and be able to fly through the WaitUntil...
    That's too bad.
    WZHomeJointDef is a part of the World option, which i do not have...
  • soup
    soup ✭✭✭
    Ah, my mistake -- maybe WaitSyncTask...
    Sadly also this is not available as it is from the MultiTasking option....
  • soup
    soup ✭✭✭
    Multiple robots, different controllers?
    Sorry, long shot -- but have to ask -- SafeMove?
    Yeah, quite a few of them all with different controllers.
    Nope, the only option I have at hand is 888-3 Profinet slave.
  • soup
    soup ✭✭✭
    Would knowing Axis 1 location help any? - If so, you could make a move instruction that checks a giAxis1 from the other robot and reports the goAxis1 location of where it'd like to move before the move is made...
    Now we're talking! Something like this maybe;
    WaitUntil ReadMotor(1) < xxx;
            Set 1_Ready;
            Reset 1_Ready;
    I noticed the ReadMotor() reads the current motor angle without the calibrated output, but if there is no other way you can think of I suppose we'll have to live with that...
  • lemster68
    lemster68 ✭✭✭
    Since you have the PLC controlling the cell, you should use it to control the safety of the robot workzones.  It is most common in these situations to do just so.  You set a request bit to the PLC, it checks that the other robot/s are out of the zone, and sets the permission to enter when all is clear.  Here is an example of one such routine:
      PROC rEnter(
        string area,
        VAR signaldo request,
        VAR signaldi wait,
        VAR signaldo going)
        CONST string stEnter:="Robot is waiting to enter ";
        CONST string stGoing:="Robot is entering ";
        ! This routine is a universal wait
        ! routine using parameters passed
        ! from the calling routine.
        ! area is string for Pick, drop, etc.,
        ! request is the robot output request
        ! to enter the area.  wait is the digital
        ! input granting permission to enter the
        ! area.  going is the robot clear output
        ! to indicate not clear.
        TPWrite stEnter+area;
        Set request;
        WaitDI wait,1;
        TPWrite stGoing+area;
        Reset going;
        Reset request;
    The neat thing about this is that no named IO are used, so you can just add it in and use it without rewriting it for your eio setup.  I am looking for some other examples.
    Lee Justice
  • soup
    soup ✭✭✭
    My last answer assumed I/O between the multiple robots to know Robot1's axis vs. Robot2's, etc. -- but I shouldn't have assumed that's needed or available.
    Play with ReadMotor and see if a smooth fly-through can be achieved, specifically \PollRate and destination zone -- virtual test below -- gave -102, -189, -181, -156...
            TPErase;
            MoveAbsJ [[45,0,0,0,0,0],[0,9E9,9E9,9E9,9E9,9E9]], vmax, fine, tool0;
            TPWrite NumToStr(ReadMotor(1),0);
            MoveAbsJ [[90,0,0,0,0,0],[0,9E9,9E9,9E9,9E9,9E9]], vmax, fine, tool0;
            MoveAbsJ [[0,0,0,0,0,0],[0,9E9,9E9,9E9,9E9,9E9]], vmax, z50, tool0;
            WaitUntil ReadMotor(1)>-200 \PollRate:=0.01;
            WaitUntil ReadMotor(1)>-200 \PollRate:=0.1;
            MoveAbsJ [[0,0,0,0,0,0],[0,9E9,9E9,9E9,9E9,9E9]], vmax, z150, tool0;
  • lemster68
    lemster68 ✭✭✭
    The problem with using ReadMotor is that there is not a one to one correspondence of motor angle to joint angle.  Use CJointT instead if that is the method you go with.  It will also be more robust because it will still be valid if, sometime in the future, the motor gets changed out.
    Lee Justice
  • VictorAx
    VictorAx
    edited July 2018
    lemster68 said:
    Basicly this is what I am doing
    soup said:
    Found a better way:
    LOCAL VAR jointtarget jReadMotor;
    MoveAbsJ Position_X,vmax,Z1\Inpos:=inpos20,tool_Rob\WObj:=wobj0;
    jReadMotor := CJointT();
    WHILE jReadMotor.robax.rax_3 > -70 DO
        WaitTime 0.1;
    ENDWHILE
  • soup
    soup ✭✭✭
    Cool - I like it. Had a chance to test the smooth flyby on a real robot?
  • VictorAx
    VictorAx
    edited July 2018
    Yep, works like a charm! I also made it into a function...
    FUNC bool MotorVal(num Axis, num AxisVal)
        TEST Axis
            CASE 1:
                WHILE jReadMotor.robax.rax_1 > AxisVal DO
                    WaitTime 0.1;
                ENDWHILE
            CASE 2:
                WHILE jReadMotor.robax.rax_2 > AxisVal DO
                    WaitTime 0.1;
                ENDWHILE
            CASE 3:
                WHILE jReadMotor.robax.rax_3 > AxisVal DO
                    WaitTime 0.1;
                ENDWHILE
            CASE 4:
                WHILE jReadMotor.robax.rax_4 > AxisVal DO
                    WaitTime 0.1;
                ENDWHILE
            CASE 5:
                WHILE jReadMotor.robax.rax_5 > AxisVal DO
                    WaitTime 0.1;
                ENDWHILE
            CASE 6:
                WHILE jReadMotor.robax.rax_6 > AxisVal DO
                    WaitTime 0.1;
                ENDWHILE
        ENDTEST
        RETURN TRUE;
    ENDFUNC
    With this after the move instruction
    WaitUntil MotorVal(3,-70);
  • soup
    soup ✭✭✭
    Nice!
