How to build an C# application to create a Robotstudio addin ?
Hello,In your project setting, in Debug tab, change Start external program to RS6.07 one.You have to do so at each RS update...Don't forget to change xsi:schemaLocation in xml files too.What I do is search text 6.06 in all the project.
☑️2024 - RobotStudio® User Group1
Hello Denis,It worked. Thank you very much0
