Use of WZSphDef
Hi everyone,
I wrote this Rapid code to control TCP position. I want the blue light(Lampe_Bleu) to be on when the TCP reach into the sphere. This code does'nt work.
       VAR shapedata Sphere;
       CONST num Rayon_sphere :=150;
       VAR pos Centre_Sphere;
       !Zone où la lumière bleue est allumée
       VAR  wztemporary ZoneRetrait_interne:=[0];
       !Zone où la lumière bleue est éteinte
       VAR wztemporary ZoneRetrait_externe:=[0];
       !Appel des alias entrées/sorties
       Demonination_entrees_sorties;
       !Affectation du centre de la sphère à surveiller
       Centre_Sphere:=rRetrait.trans;
       TPWrite "centre de sphère" \Pos:=Centre_Sphere;
        ! Activation de la lumière bleue à 150 mm de la position rRetrait
        WZFree ZoneRetrait_Interne;
       WZSphDef\Inside,Sphere,Centre_Sphere,Rayon_sphere;
       WZdoset\temp,ZoneRetrait_Interne\Inside,Sphere,Lampe_Bleu,Allume;
        ! Desactivation de la lumière bleue à plus 150 mm de la position rRetrait
        WZFree ZoneRetrait_Externe;
        WZdoset\temp, ZoneRetrait_Externe\inside,Sphere,Lampe_Bleu,Eteint;
        WzEnable ZoneRetrait_interne;
  • soup
    soup ✭✭✭
    At a glance, the enable code needs to be placed inside procedures and then those procedures need to be called when you want the zone active.
  • Thank Soup.
