Cannot connect to VC (localhost)
tlt
Good afternoon!
I installed the Robot Studio 6.07, created new project. VC is active (right bottom bar is green). I try to connect to VC with IE or Chrome. I write, example, 127.0.0.1/rw. Then I get pop up message with login and password. Popup up says me about validusers@robapi.abb.
Could you clarify what login and password I need to put?
Thank you!
Thank you!
In the manual, available here: http://cdn.robotstudio.com/documentation/18.1/en/3HAC032104 OM RobotStudio-en.pdf, one can find the following information:
"All controllers have a default user named Default User with a publicly known password robotics. The Default User cannot be removed and the password cannot be changed. However, a user having the grant Manage UAS settings can modify and restrict the controller grants and application grants of the Default User."
I hope this helps you.
—Maxim RiabichevPC Software Support Engineer5
