WWSDK- VCSendTPUKeys ? [WebWare SDK]
in WebWare
Does anybody have a list of the keystings, how VCSendTPUKeys Method could be used in WWSDK?
Regards Kevin
Hi Kevin,
Here is a copy of a reply I got from Vasteras by way of G'Burg:
Below follows a function of how to"click" the different functionkeys.
Declare a string with 8 signs and give it the following data:
str[0] 0x1b
str[1] [
str[2] 0
Then add the following to the str:
for function1 "17~"
for function2 "18~"
for function3 "19~"
for function4 "20~" (Cancel-button for Auto mode)
for function5 "21~" (OK-button to confirm to Auto mode)
unsigned char str[8];Russell Drown0
- 359 IRC5
- 77 OmniCore
- 851 RAPID Programming
- 30 AppStudio
