Syntax for argument with '|' seperator
for a procedure I need the possibility to combine two arguments with a OR character.
With optional arguments it works fine, but I don't wanna use optional arguments.
The following code is not accepted.
PROC SetValue(num Value<b>|</b>dnum Dvalue)
I want the independence of the data type for calling SetValue.
VAR num Value;
VAR dnum Dvalue;
SetValue Value;<br>SetValue Dvalue;<br>
I found a code example in the manuel for the procedure SetGo.
This is the syntax from the robotware manuel "technical reference manual - RAPID Instructions, Functions and Data types" on page 688.
SetGO
[ '\' SDelay ':=' < expression (IN) of num > ',' ]
[ Signal ':=' ] < variable (VAR) of signalgo > ','
[ Value ':=' ] < expression (IN) of num >
| [ Dvalue' :=' ] < expression (IN) of dnum > ';'
I hope someone can help me.
Thanks in advance!
  • Hello,
    We've looked into this and because RAPID does not support overload you'll have to 'normalize' the variable before you call the function. With normalize I mean convert to either num or dnum.
    Consult the RAPID manual on how to do the conversion.
    Maxim Riabichev
    PC Software Support Engineer
  • soup
    soup ✭✭✭
    Interesting question! So, what kind of magic does the SetGO function have behind the scenes that it's able to do the num or dnum without conversion?
  • Hello Maxim Riabichev,
    thank you for your response!
    I know the conversion function, but from a programmer's point of view it would be fantastic if two non-optional arguments could be combine with "or".
    The SetGo command illustrates the advantages!
    I think it would be great if this possibility would be added in a future robotware update.
  • Hello,
    Okay I'll have a talk with my collegues tomorrow.
    Maxim Riabichev
  • Hello,
    So we've spoken about this matter and we've reached the conclusion that the best would be if RAPID would support Overload, like C# does for example.
    I will move this thread to the UpFeed section (as a suggestion for future addition to RAPID).
    Maxim Riabichev
  • Hello,
    Glad to hear it.
    Thanks for everything.
    Kind regards
