IRB6400 3426 (trying to restore the EIO)
Hello,<br>I have an OLD OLD OLD Robot in which disk one is not loading back to the system.<br><br>The power was lost and therefore the memory was lost.<br><br>Trying to load back in Disk 1 it just keeps searching for ABBIOC.000 file.<br><br>I finally got the system to load using another Disk one from another Robot however there are no I/O's in the system.<br><br>How do I load the EIO.CFG files into the robot?<br><br>Thank you ahead of time
Probably S4? Have a backup or saved syspars? Need to go to System parameters/Load.Lee Justice0
Yes it is an S4
i do have a back up
I can load the backup just can’t reload the EIO file.
Thank you for the response.0 -
The file is corrupt? How much IO does it have? If not much, you could go into system parameters and manually rebuild it.Lee Justice0
There are A LOT of I/Os and I mean A LOT0
Have you tried loading just the EIO file as Lemster suggested from parameter's->load (you will find the EIO file in the SYSPAR directory of the backup)?
This should give you an error message if the file can not be loaded - the error should help find what the issue with the file is.
how would I load just the stand alone EIO File?0
go to the miscellaneous menu->system parameters (as above)
Then file->load parameters (your menu may be slightly different as these snips are S4C+)
- 398 UpFeed
- 300 PowerPacs
- 336 IRC5
- 67 OmniCore
- 828 RAPID Programming
- 11 AppStudio
