Copying Target Orientation
Can someone list the steps to copy the target orientation for RobotStudio 6.03, I have not had much luck with any searches in the forum. Kind Regards, Atikus
Right-click on the target > Copy Orientation1
Soup, there is no option for me to choose from when I right click on a target to select copy orientation.
That's the path rather than the target -- common confusion. From your screen shot, choose Locate Target. Then right-click on the target and you should see Copy Orientation there.
- 341 IRC5
- 69 OmniCore
- 840 RAPID Programming
- 19 AppStudio
