HOW i create workobject without 3 point ?
hello
i want to create workobject at center of coil ,but coil is no axis for select to create workobject.
i want to create workobject at X .
Thanks for the help.
  • Move your tcp to the center, write down the coordinates, x,y,z.  Manually put those coordinates into the workobject, change orient to 1,0,0,0, or other value if desired.
    Lee Justice
  • Thank you very much
