HOW i create workobject without 3 point ?
antpp_30
hello
i want to create workobject at center of coil ,but coil is no axis for select to create workobject.
i want to create workobject at X .
Thanks for the help.
Move your tcp to the center, write down the coordinates, x,y,z. Manually put those coordinates into the workobject, change orient to 1,0,0,0, or other value if desired.Lee Justice0
Thank you very much0
- 367 IRC5
- 858 RAPID Programming
