Pickmaster Robotware options missing error
I have just installed RobotStudio 6.07.01 SP1 with RobotWare 6.07.01
I've downloaded the Picking Powerpack 6.06. with the Virtual Pickmaster 3.54.
When i've added the picking controller a warning appears:
My configuration for the options is:
I dont see what i'm missing. I've also tried "One I/O board DeviceNet " option from PickMaster IO configuration selection but its still the same.
I tried to use an older Robotware 6.05 version as well. This worked, but the system crashed as soon as I wanted to calibrate the base frame. Conveyors/Workareas/Cameras i've added are all default settings.
Please advise, thank you.
Harry
Harry
The problem I had came from using RS version 6.07(with RW 6.07) and Picking PowerPack 6.06. All these software versions have to match.
ABB sent me RS 6.06 and I got it running.
