smart component source copy I/O
Hello all,
I have a problem with copies of my smart component. My original SC has connected signal from rapid. The original SC is working, however if I make a copy of SC the other copies does not react to the signal triggered from rapid.
here is my signal connection to SC called maska1. If I have a copy let's say maska1_1 DO signal doesn't work in that copy because it's still only connected with thhe original. New I/O connection isn't created. I need a lot of dynamic copies and don't know how to solve this. Please help.
Thank you
  • The problem is here:
    maskaA1_126 is copy thhat was made automatically with source component. The input signals aren't automatically connected. I can't find a way how to solve this
