DSQC 344 - CMD TOOL
I have a problem with DSQC 344 communicating.
I want to configure DSQC 344 Interbus Board via Phoenix Cmd tool.
But i couldn't be online.( I think i couldn't set true parameter for rs232 connection)
Is there anybody who have experience before about this issue ?
Regards
  • it must be defined in the CMD the type;
    IBS SC/RI/I-T PCI
    then try again
  • Hi sevushka
    WE have solved the connection problem.We have got PSS Bosch Timer and 2 items IBS IP CDIO/R 24-8/SF.My question about the connection between Bosch Timer and CDIO modules. We need small explanation about the connections. First of all we have connected DSQC 344 to Bosch Timer's in port  and Bosch Timer's Out port to CDIO/R.
    But we weren't sure that neither true connection has been made or not . Have you got any circuit diagram about this issue ?
    Regards
  • Hi Sevuska
    Have you got an email ?
    Could you send me ?
    Regards
  • Hello I have:
     - IRB 6400, M97, S4C + InterBus DSQC 344 (Phoenix Contacto)
    I have already installed the IBS CMD G4 software. I need to know how to configure the InterBus in the S4C driver (or how to know if it is configured correctly) and how to configure the IBS CMD G4 software.
    Please I need your help.
    Thank you!!!
