Signal Analyzer Online
Hello there!
I'm working with a IRB-120 with robotware 5.15.02 installed and I want to use the signal analyzer online, but it's grayed out and I can't use it. I've read that it only works on 5.15.03, but I can't find the files to upgrade my robotware to that version. Is there a way for me to use that tool in my version? If not, where can I find the files needed to upgrade to 5.15.03? I can upgrade to 5.15.14, 5.15.15 or 5.15.16; does signal analyzer online work on those versions?
Thanks in advance
  • Hi,
    It requires 5.15.03 or higher, so 5.15.14 etc. should be fine.
    Regards,
    Johannes
    Johannes Weiman
    RobotStudio Team, ABB Robotics
