RW version
https://new.abb.com/products/robotics/robotstudio/downloads
Scroll down to downloads section (near the bottom of the page), then select Software in the left-hand section -> you will then find RW5.15.xx in the right hand section (have to go a long way down)
1 -
Many thanks for your reply
In downloads section shows only 2 softwares itens and none is robotware 5.15.20
I already have the version 5.15.15 intalled, but cant create system from 5.15.20 backup. Says thats version missing in mediapool
Try here: http://www.abb.us/AbbLibrary/DownloadCenter/?showresultstab=true&browsecategory=9AAC910011&displayversion=1&dockind=Software#&&/wEXAQUDa2V5BYYBM8KwOUFBQzkxMDAxMcKxwrHCsVNvZnR3YXJlwrHCsVTCscKxNMKxZW7CsTI5wrFVU8KxwrEywrFUwrEwwrHCsTDCsTHCsTIwwrEyMMKxMcKxwrHCscKxwrE5QUFDOTEwMDExwrHCscKxwrExMcKxwrHCscKxMTA5wrHCsTDCsVVTwrHCsTB2D5RLJEyZklxPpL/j8bzXXZw8wg== If you cannot find the exact version, get one newer. Then, in system builder you should be able to tell it to use a newer version. And, just for info for everyone else I will share this link: http://www.abb.com/abblibrary/DownloadCenter/?showresultstab=true&categoryid=9AAC910011#&&/wEXAQUDa2V5BX8zwrA5QUFDOTEwMDExwrHCscKxwrHCsVTCscKxNMKxZW7CsTI5wrFVU8KxwrEywrFUwrEwwrHCsTDCsTHCsTIwwrEyMMKxMcKxwrHCscKxwrE5QUFDOTEwMDExwrHCscKxwrExMcKxwrHCscKxMjg1OcKxwrEwwrFVU8KxwrEwWS8gGjjJ/FFijJfR+R/59oGPrYg= I hope they work!Lee Justice0
A few years back, before ABB's awesome website redesign
, they had a simple list of all the RobotWare on a server that ABB support provided. I'd spend 2 seconds searching "RobotWare 5.15.2005.02" in the Downloads and when that didn't work call ABB support and demand better service...
- 367 IRC5
