Stop programpointer without stopping Robot
I'm trying to optimize an Glue robot. Between every glue-string there is an Checkbead to check if the Glue-string was ok or not.
This takes cycletime, approx 1 sec per bead.
Been trying to optimze this and not to stop the robot inside the Checkbead routine but without success.
The problem is that the robot stops in an Waittime/inpos instruction. This instruction is used cause the program pointer jump's so much forward in the rapid code. If we don't use the
waittime/inpos instruction the Program pointer resets the bead so we don't get any glue.
My question is if there is any instruction I can use to stop the program pointer without stopping the robot. Anyone who had similar problems?
Here is the code in the "work-routine"
Proc Myworkroutine()
Toolchange Doser511;
PrepareEquipment Doser511,HomeDoser511;
Doser511AutoPurgeSch;
MoveAbsJ HomeDoser511,vmax,fine,Doser511TCP;
MoveJ ToBS1_10,v2000,z50,Doser511TCP\WObj:=BSStn020;
PrepareBead bdbead 1_1;
MoveL ToBSdb30,v2000,z50,Doser511TCP\WObj:=BSStn020;
DispL\ON,BSdb_Start,v150,bdbead1_1,z5,Doser511TCP\WObj:=BSStn020;
DispL\OFF,BSdb70,v150,bdbead1_1,z5,Doser511TCP\WObj:=BSStn020;
MoveL BSdb71, v150, z50, Doser511TCP\WObj:=BSStn020;
CheckBead bdbead1_1;
PrepareBead bdbead2_1;
DispL\ON,BSdb50,v150,bdbead2_1,z5,Doser511TCP\WObj:=BSStn020;
DispL\OFF,BSdb60,v150,bdbead2_1,z5,Doser511TCP\WObj:=BSStn020;
MoveL BSdb70, v150, z50, Doser511TCP\WObj:=BSStn020;
CheckBead bdbead2_1;
PrepareBead bdbead3_1;
DispL\ON,BSdb73,v150, bdbead3_1,z5,Doser511TCP\WObj:=BSStn020;
DispL\OFF,BSdbEnd,v150, bdbead 3_1,z5,Doser511TCP\WObj:=BSStn020;
MoveL ToBSdb30, v150, z50, Doser511TCP\WObj:=BSStn020;
CheckBead bdbead 3_1;
_____________________________________________________________________________________________________________
Here is the code inside the Checkbead routine
Proc Checkbead()
IF dp_dry=FALSE THEN
! Wait until previous bead finished
WaitUntil NewBeadOk=TRUE\MaxTime:=10\TimeFlag:=timeout\PollRate:=0.02;
WaitUntil DInput(I_BeadActive)=0\MaxTime:=30\TimeFlag:=timeout\PollRate:=0.02;
WaitTime\InPos,0;
! Reset Bead number to disp. equipment
WaitTime 0.02;
SetGO GO_BeadNo,0;
SetGO GO_PartAreaNo,0;
!CheckInput I_ReadyToDose,1\CheckTimeOut:=3\AlarmNumber:=A_DispSystemNotOK,strVolumeError531;
WaitTime 0.03;
! Save the bead cons. to memory Volume
Volume:=(AI_BeadCons);
! Check if the volume in the bead was OK
IF DInput(I_BeadVolumeOk)=0 THEN
! Set local variable O_ErrorApplic
SetDO O_ErrorApplic,1;
! Ändrat 180116 för att spara volumfel till bVolumeFault
bVolumeFault:=TRUE;
! Get errortext
SaveDispErrorTxt;
! Asign information to Disp_ErrorTxt
Disp_ErrorTxt{8}:=targetId;
Disp_ErrorTxt{9}:=" Material consumption "+NumToStr(Volume,3)+"CCM";
Disp_ErrorTxt{19}:=targetId;
Disp_ErrorTxt{20}:=" Material förbrukning "+NumToStr(Volume,3)+"CCM";
! Operator comunication
!CheckInput I_BeadVolumeOk,1\CheckTimeOut:=3\AlarmNumber:=A_DispSystemNotOK,strVolumeError531;
WHILE DInput(I_BeadVolumeOk)=0 DO
ErrDisplay 1,key_in,A_DispVolumeError,Disp_ErrorTxt,stBuPROCEED_5\stProcessID:=processId;
! Reset alarm in disp. equipment
PulseDO\High\PLength:=1,O_ResetAlarms;
WaitTime 1.2;
ENDWHILE
!ErrDisplay 1, key_in, A_DispVolumeError,Disp_ErrorTxt,stBuPROCEED_5\stProcessID:=processId;
! Reset alarm in PLC
SendAlarm A_DispVolumeError,""\sum_alarm\Reset;
Try making and using your own StoppointData, read up on it in the manual.Lee Justice0
MoveLSync....Good call Soup.Lee Justice0
I used the MoveLSync an created a new routine were I set an bool and with that bool I used a while loop inside the Checkbead routine to "catch" the PP inside the while loop until I reached my MoveLSync pos.
seemed to work. Thanks for the help guys.0 -
No problem, glad it worked. Thanks for the shout-out @lemster68
