Virtual Controller folder being moved from original location
ko414du4
Hi all,
I have a few pack and go files and I would like to join all the unpack-and-work folder under 1 solution. The solution file detects there are more than one stations available in the folder - Great! But, every time I want to start a station, robotstudio cannot start the controller, saying that it has been moved or deleted. It gives me the option to locate it myself but when I do that, after a very long wait, it comes up with an error that there is no response from the controller.
Any solution to this please? Thank you.
Try to take a backup of the original controller, then create a new VC from the backup in the desired location.
Regards,
Johannes
Johannes Weiman
RobotStudio Team, ABB Robotics5
Thanks Johannes.0
vc is giving problem, i am not able to change the folder and above points is not giving a solution0
- 303 PowerPacs
- 353 IRC5
- 850 RAPID Programming
- 25 AppStudio
