Virtual Controler Problem. It doesn't work.
I have a big problem with virtual controller RobotStudio. VC doen't start. I get a messange "there was a problem when starting the virtual controller".
I uninstaled RobotStudio. I cleanned all folder related with RobotStudio on Program Files folder and Commond Files folder, but VC doesn't work. I am desesperated.
I am working on Windows 10 and RobotStudio 6.07.
Try upgrading to RS6.08.
How did you create the VC?
I have tried install RS 6.08, but the problem is the same,
Post edited by J.C.M.Castillo on0 -
I have the same problem when try to open a "pack e go" simulation
- 364 IRC5
- 81 OmniCore
- 853 RAPID Programming
- 32 AppStudio
