What's the best way to add a comment on FlexPendant?
jsph
What's best way to add a comment when programming on the flexpendent?
I can see how to comment an instruction, which I can then edit, but it seems a bit of a workaround.
Cheers, Joe.
Cheers, Joe.
to add a comment you have to add a new instruction and select "Comment" in the palette "Various" on the right side.
An empty comment is added.
Then you change to menu "Edit" and press the button "ABC..." to enter the text of your comment.
BR
Micky0 -
Hello,In Program Editor, Add Instruction,Various, Comment.☑️2024 - RobotStudio® User Group0
Is there a direct way to insert empty line on the FlexPendant?
Hello,I don't think so.Prefer add empty comment line.☑️2024 - RobotStudio® User Group0
- 367 IRC5
- 858 RAPID Programming
