RSO JOB read out hole Message Errorlog
Hi every one, i used the job function in RSO to read out Eroor Messages et al. Thats working fine and is vervy helpful for me.
The Problem is, that i can only read out the Message title from the Error and not the hole Message.
Maybe anyone has an idea to realize this, to get the title and also the message text.
The normale prodzedure from RSO ist that i get out an excel file tih the data, this is what i need. only missing the hole text in the file.
Thanks a lot
  • Hi,
    The whole Description is already included in the result.
    Do you mean that you also need other fields such as "Consquences", "Causes" and "Actions"?
    Regards,
    Johannes
    Johannes Weiman
    RobotStudio Team, ABB Robotics
