Get the name of the current tool
scottMHA
That doesn't return the name? it just returns the frame, load and robheld0
Ah, sorry, reading too quickly. How about GetSysData?
my understanding of that function is that you can retrieve the values of a data type from the object name?
I want to just get the name of the current tool being used whilst jogging... must be a way as ABB display it when running the tool identify routine in the basefun tasks0 -
Using Example 1 & 2 from the manual -- it outputs the current tool as a string value:MODULE mMain
PERS tooldata curtoolvalue;
VAR string curtoolname;
PROC main()
GetSysData curtoolvalue \ObjectName := curtoolname;
TPWrite curtoolname;
ENDMODULE
1
- 398 UpFeed
- 13 RobotApps
- 300 PowerPacs
- 405 RobotStudio S4
- 330 IRC5
- 66 OmniCore
- 826 RAPID Programming
- 10 AppStudio
- 105 Collaborative Robots
