Targets disappear after an unsuccessful attempt to Cut-Paste
in UpFeed
It seems that Cut-Paste functionality of Paths&Targets has a small issue with pasting Targets to workobjects/other targets. Whenever I try to paste a previously cut target into other target/workobject an error "Move target to workobject failed." (see img) is generated and the original target is erased from its location.
I did not find this issue to be reported previously, but, apparently, RS versions 6.06 - 6.08 has it.
Stefan
Stefan
When moving or copying are target between workobjects you should right click and use the move to workobject or copy to workobject option.
Alright, so it is not a bug but a feature
. Thank you for the explanation! 0
