C# application - pointer location.
I figured it out.0
Hello,Here is the solution. May be useful for others.
Thanks vikram6892. I did almost the same.t = aController.Rapid.GetTask("T_ROB1");var p = t.ProgramPointer;var outputRow = p.Range.Begin.Row.ToString();0
