WpfTreeView
Hello everybody,
has anyone ever created a TreeView using the WpfTreeView class offered by RobotStudio SDK in c#? I found it very unlike to the standard WPF treeview in C#. Could anybody give me a program demo showing how to use it? Thank you.
I have written some sample code but I'm not sure where it ended up.. Check this space.
Johannes Weiman
Johannes Weiman
Thanks for your response. Did you forget to attach the link or something? I cannot see any space you mentioned.0
It's right there but here it is again:
http://developercenter.robotstudio.com/Index.aspx?DevCenter=RobotStudio&OpenDocument&Url=html/12cabae3-0de1-4305-913d-514beda53a36.htmJohannes Weiman
Got another question. Could anybody give an example how to add an context menu for rightclicking a node in the tree?
And in addition to that is it possible to disable the multiselection of nodes?0
Thanks a lot JWeiman. This is exactly what I need.
Hi Mr. Johannes Weiman,
The link leads me to the home page of the development center (http://developercenter.robotstudio.com/landing), not to exact location of your link. Can you please post the updated link to look into WPF treeview in C#.
Thank you for the support.
Best Regards,
VINOTH KUMAR THANGAVEL.0 -
Johannes Weiman
Thank you Mr. Johannes Weiman for the support.
Is it possible to add "WpfTreeView" object to "ToolWindow" object? I wish to display a treemodel in the left side docked tool window.
Thank you for the support.0 -
Sure, you can add a WPF control to a Windows Forms container by using an ElementHost.
https://docs.microsoft.com/en-us/dotnet/api/system.windows.forms.integration.elementhost
Johannes Weiman
Hello Mr. Weiman,
Unfortunately the link leads me to the home page of the development center.
Can you please post the updated link to look into the sample code for WPF treeview in C#.
Really thank you for the support.
Best Regards,
S.V.0
