Force control in robotstudio machining package is not active
Hi all,
Force control in robotstudio machining package is not active in my robotstudio software. Any one have any idea?!
Abd El Khalick
you need to add the FC option to your virtual System:
Then open a new Station with your existing System and select I-Start to activate the new Options
Open Machining PP, it adds the FC instruction templates to your Station and you may use it as template....
regards
regards
Christian0 -
Now it works. Really I appreciate you help too much.
How can i "add the FC option to your virtual System"Christian_Goy said:Hello,
regards
my device:
How can i "add the FC option to your virtual System"Abdelkhalick said:Now it works. Really I appreciate you help too much.
my device:
You might already have gotten an answer but in case you have not.
You add the option through the Installation Manager in robotstudio. (Icon that looks like a IRC5 cabinet)Best regards
Alexander Källberg0
- 367 IRC5
- 858 RAPID Programming
