Maximum allowable bit transfer between Allen-Bradley PLC, and an ABB IRC5 with Ethernet/IP
Mjsh635
Can someone point me in the direction of some reference material regarding Ethernet/IP communication setup, such as maximum input and output size setting and such.
0 -505 bytes in and 0 - 505 bytes out. Maybe 509, manual is a little vague. 3HAC050998Lee Justice5
Depends on the adapter -- what's the part number?
