Tool data analysis problem
Is there a quick way to parse the data of Tool.data into a data display type similar to RobotStudio virtual controller? Still using ordinary strings for processing?
Convert into
Convert into
Not sure i understand what you are asking for? How and what do you want it displayed on/in?dapeng17951 said:Is there a quick way to parse the data of Tool.data into a data display type similar to RobotStudio virtual controller? Still using ordinary strings for processing?
Convert into
You can create a basic winform and design the UI to look like the pendant?0 -
Are you asking how to get direct access to the parts of tooldata? If so, look at the "Basic Example - Example 2" of tooldata in the manual: "gripper.tframe.trans.z := 225.2;0
