File not found or could not be opened for reading
                    I follow the given sample code.When I am trying to load one module to the real controller , it returns the error : RobotStudio .NET exception:  File not found or could not be opened for reading. However , the  module does exist . Here is  my code , any idea? I am a green hand ,thanks a lot !
                private static void button_ExecuteCommandSecond(object sender, ExecuteCommandEventArgs e)
            // Step 1: Connect to the controller
            #region LMStep1
            Guid systemId = new Guid("7fa807ce-c383-42b6-8a32-549fcb4cb50d");
            Controller controller = new Controller(systemId);
            controller.Logon(UserInfo.DefaultUser);
            #endregion
            // Clears the eventlogs in the controller
            controller.EventLog.ClearAll();
            // Gets the task with the specified name.
            ABB.Robotics.Controllers.RapidDomain.Task tRob1 = controller.Rapid.GetTask("T_ROB1");
            // Step 2: Select module from PC
            #region LMStep2
            if (System.IO.File.Exists(@D:\Temp\MyModule.mod))
                    string ModulefilePath = @D:\Temp\MyModule.mod;
                    bool bLoadModuleSuccess = false;
                    // Step 3: Load Module
                    #region LMStep3
                    using (Mastership.Request(controller.Rapid))
                        // Loads a RAPID module to the task in the robot controller.
                        Logger.AddMessage("The mastership has been gotten.");
                        bLoadModuleSuccess = tRob1.LoadModuleFromFile(ModulefilePath, RapidLoadMode.Replace);      // According to the report ,here happens the error.
                    #endregion
#endregion
#endregion
            Hey hanpeiwen,
 I know it's been a while, but did you ever solve your question above?
 I'm sitting here with what I believe is that same problem. My code closely resembles ABB example for uploading a mod fiel to a controller and it even works on a virtual one.
 But as soon as I try it on a physical controller I'm getting the error file not found.
 Was hoping you or someone else might have some suggestions to what I'm doing wrong.0
            Hello,I think you have to copy your file to the controller before you can load it from there.As I know it is not possible to load a file directly from the PC into the real controller.You can use the following method to copy your file:aController.FileSystem.PutFile(localFilePath, remoteFilePath); See also the following link:Best regardsMicky
            Hello,Physical controller use Unix folder separator '/'.Filename could be like this: "HOME:/myfilename.txt".Look at Open instruction in RAPID manual.You can use RobOS() to know if you're running in virtual or real robot.☑️2024 - RobotStudio® User Group0
- 363 IRC5
- 80 OmniCore
- 853 RAPID Programming
- 31 AppStudio
