A way to move a robot without worrying about the orientation of the tool
Mechie
Is there a move command that lets me move the robot only based on a given position and doesn't need the orientation of the tool to be specified?
MoveAbsJ. It tells the robot to go to absolute joint angles specified by a jointtarget.Lee Justice0
MoveAbsJ won't work as I have a position, but not the joint angles.0
Hello,You can force orient data of your robtarget.☑️2024 - RobotStudio® User Group0
MyjPos:=CalcJointT(MyRobtarget,MyTool\Wobj:=MyWobj)
MoveAbsJ MyjPos, blah, blah, blah;Lee Justice1 -
Thank you lemster68.0
- 359 IRC5
- 77 OmniCore
- 851 RAPID Programming
- 30 AppStudio
