Installation of downloaded Smart Component from Addins tab
sturner
In the downloaded smart components zip file I find xml and .bin files.
Where / how are these installed in order to use the Smart component.
FYI, I'm hoping to use Anders Tube Trace
Hello,This is a bug I want to raise.You cannot install addin directly from Add-ins tab.But you can go to RobotApps link then download rslib file.Then in your Station Logic, you can add your downloaded library.Hope this will be fixed in next release.
☑️2024 - RobotStudio® User Group0
