RobotStudio 6.08.01/ download problem
We have identified that there was an issue with the installation files on one of our download servers, please re-download from https://robotstudiocdn.azureedge.net/install/RobotStudio_6.08.01_2.zip and you should be able to successfully install the software.
Liam6
Hi elclou, do you get any specific errors when trying to unzip the file?0
Hello,What is your SHA-1 value?Mine is SHA1: 1E5A74BB2AB14919524FB525E710E88B29C55DFC
Should be given by ABB.I can unzip it with 7zip but cannot make an iso from unzipped folder...☑️2024 - RobotStudio® User Group0 -
DenisFR said:@Liam_ABB : Could you add SHA1 next download button so we can know if downloaded file is correct?
Thanks for the suggestion!
As this issue was an extremely rare occurrence of a problem with the downloads for RobotStudio which has been identified and resolved, it has been decided that it would not be necessary to add that to the page.
Liam0 -
Thanks Liam0
Liam said:Hi,
Liam0
- 303 PowerPacs
- 353 IRC5
- 850 RAPID Programming
- 25 AppStudio
