Find/Replace
mdb17
I am having an issue using Find/Replace in 6.07. Whenever I try to use either the keyboard shortcuts to the buttons on ribbon nothing happens. I can click on the button and nothing. Is anybody else seeing this issue?
I've got the same problem if i the 4k resolution. With full HD it's ok.0
mdb17, I'm having the same issue in 6.08. Did you ever resolve it?0
Hello,Works fine here in 6.08.Can your Find/Replace window be outside your desktop?What I see is, if you put the F/R window near corner then change screen resolution, the window stay at its older position so you cannot see it.
This is a known issue if your DPI setting is greater than 100%.
- 367 IRC5
- 858 RAPID Programming
