How to control ABBs motor units in Robotstudio?
Hi! I'm doing a thesis where I will use an ABB motor unit, MU.
In Robotstudio, RS, I would like to control the MUs speed, the degree and so on. So far I can only control the MU by making it a mechanical unit and then controlling the external axis by ordering the MU to turn a certain amount of degrees.
I tried Independent movement such as IndAMove IndRMove, but I fail to make it work.
This is the error message that I get:
System1/RAPID/T_ROB1/Module1(30,9): Option is missing(161): The instruction IndRMove requires the option Independent. 2019-03-27 17:37:45 General
I did try to find information about Independent movement online, but none of the hits I got on google where working, they are all dead.
Is there anyone out there that has some knowledge or hints about this?
Best regards
/Dahniel
Best Answers
  • Hi Lemster :)
    I did this already (I think). Plesae see attached picture.
  • Thank you for your reply, I am very grateful for your time and your patience.
    RS ask me for a "Controller Key which I don't think I have.
    When I check the Virtual Key option, i can't choose the RobotWare Version, it is just blank (see pic below).
    I assume I should browse to a certain folder in to be able to choose the RobotWare Version, but I can't find the correct folder.
    C:\Program Files (x86)\ABB Industrial IT\Robotics IT\RobotStudio 6.08 and then what?
  • Yes I realized that this morning. Thx!!
    I guess this is what you mean.
  • Hi, I still have a problem.
    The following is my procedure.
    1.       Create empty station
    2.       ABB library: IRB140 and MU80
    3.       Installation manager
    4.       Create new system
    5.       Name the system, next
    6.       Add, Motor and GearUnits 6.08, OK, Next
    7.       Added Licence(s) RobotWare and MotorAndGearUnits, next
    8.       System options, check Independent axis
              Drive Modules, no changes
              Applications, no changes
              next
    9.       Confirmation, Apply
    10.   Install will update the controller with your selections and install  Product(s) / License(s)., Yes
    11.   Error message popup:
            Unhandled exception was encountered.
            Object reference not set to an instance of an object.
            Do you want to Retry, else the application will be closed?
    What am I doing wrong?
  • Thanks so much! Unfortunately, it's still the same error message.
  • What version of RobotStudio do you have?
    ABB Robotics
  • 6.08
  • For some reason I don't get the error message any longer. :)
    So now I created a system from Existing system. So far so good.
    But ofcourse I ran in to trouble when I simulated.
  • Thank you so much guys!!!
