How to control ABBs motor units in Robotstudio?
Hi! I'm doing a thesis where I will use an ABB motor
unit, MU.
In Robotstudio, RS, I would like to control
the MUs speed, the degree and so on. So far I can only control the MU by making
it a mechanical unit and then controlling the external axis by ordering the MU
to turn a certain amount of degrees.
I tried Independent movement such as IndAMove
IndRMove, but I fail to make it work.
This is the error message that I get:
System1/RAPID/T_ROB1/Module1(30,9): Option is missing(161): The instruction
IndRMove requires the option Independent. 2019-03-27 17:37:45 General
I did try to find information about Independent movement online, but none of
the hits I got on google where working, they are all dead.
Is there anyone out there that has some knowledge or hints about this?
Best regards
/Dahniel
Best Answers
Go back into your system with system builder, add the independent axis option.Lee Justice5
No, not there, installation manager, system builder, or whichever is appropriate for your RW version.Lee Justice5
Here should the media pools for RW 5 be installed:
C:\Program Files (x86)\ABB Industrial IT\Robotics IT\MediaPool
But probably is your system using RW 6.xx, and in that case should you use Installation Manager, not System Builder.
ABB Robotics5 -
Yes, correct.Best regards,
ABB Robotics5 -
Add these settings:
//Anders
ABB Robotics5 -
Go back into your configuration like you posted yesterday.Lee Justice5
Hi Lemster
I did this already (I think). Plesae see attached picture.
Thank you for your reply, I am very grateful for your time and your patience.
RS ask me for a "Controller Key which I don't think I have.
When I check the Virtual Key option, i can't choose the RobotWare Version, it is just blank (see pic below).
I assume I should browse to a certain folder in to be able to choose the RobotWare Version, but I can't find the correct folder.
C:\Program Files (x86)\ABB Industrial IT\Robotics IT\RobotStudio 6.08 and then what?
Yes I realized that this morning. Thx!!
I guess this is what you mean.
Hi, I still have a problem.
The following is my procedure.1. Create empty station
2. ABB library: IRB140 and MU80
3. Installation manager
4. Create new system
5. Name the system, next
6. Add, Motor and GearUnits 6.08, OK, Next
7. Added Licence(s) RobotWare and MotorAndGearUnits, next
8. System options, check Independent axis
Drive Modules, no changes
Applications, no changes
next9. Confirmation, Apply
10. Install will update the controller with your selections and install Product(s) / License(s)., Yes
11. Error message popup:
Unhandled exception was encountered.
Object reference not set to an instance of an object.
Do you want to Retry, else the application will be closed?What am I doing wrong?
Thanks so much! Unfortunately, it's still the same error message.
What version of RobotStudio do you have?
6.080
For some reason I don't get the error message any longer.
So now I created a system from Existing system. So far so good.
But ofcourse I ran in to trouble when I simulated.
Thank you so much guys!!!
