Syntax Error - RS Online
I was trying to pass an array of robtargets to a procedure, but I was getting a syntax error from the program editor when passing multiple arguments. To simplify this, I tried the following example from Section 22.4 Routine Declarations of the Rapid Overview manual:
VERSION: 1
LANGUAGE: ENGLISH
MODULE Module1
VAR num globalarray{9}:=[1,2,3,4,5,6,7,8,9];
PROC arrmul(VAR num array{*},num factor)
FOR index FROM 1 TO dim(array,1) Do
array{index}:=array{index}*factor;
ENDFOR
PROC main()
arrmul(globalarray,5);
ENDMODULE
When applying the changes, RS Online gave the following error messages:
/T_ROB1/Module1/(14):Error 40135:Syntax error.:Expected ')
/T_ROB1/Module1/(14):Error 40136:Syntax error: Unexpected ')'
I have tried a variety of variable declarations with no change in the results. I am using RS 5.7.1834.1023 and RS Online 5.7.1025.0
Any help would allow me to keep my remaining strands of hair.
Thanks,
Hi Jim,
It's your procedure call that is incorrect; procedures don't use parentheses:
PROC main()
arrmul globalarray,5;
Johannes Weiman2006-10-26 9:19:24Johannes Weiman
Thanks, that was it. I figured it was something simple, but I sure couldn't see it.Jim Haglund0
- 304 PowerPacs
- 354 IRC5
- 850 RAPID Programming
- 26 AppStudio
