How to fix the problem in filtering the signals in PC SDK application?
SignalCollection Signals = MainController.IOSystem.GetSignals(IOFilterTypes.Digital).Where(o => o.Type == SignalType.DigitalInput) as SignalCollection;
Should be able to use linq to filter these out. Not sure if it works with a collection, you may have to parse through signals individually. Alternatively use the code below.SignalCollection Signals = MainController.IOSystem.GetSignals(IOFilterTypes.All); foreach(Signal signal in Signals) { if (signal.Type == SignalType.DigitalInput) { // Do something here to inputs } }
I think you have to use a binary OR (|) instead of a binary AND (&) to be able to use several filter settings.var Signals = <span>MainController.</span>IOSystem.GetSignals(<b>IOFilterTypes.Digital | IOFilterTypes.Input</b>);
Best regards
Micly0
