Change hard disc
jooli
Somebody told me that his possible to change the hard disc on IRC 5 to a big one.
After prepare the hard disc in two part ions (BOOT, USER) and format in FAT, I copy all the files as the original.
After restarting the robot, was not possible established a connection to the robot controller.
I would know if somebody can give me some help to make the change.
Could you tell me that which size hard disk do you wanna use ?
Have u got a image of old files ?
If you haven't i can send them.
Best regards
hii sinan what a suprice to see you on this portal
