Add a mechanism to a station already created
I would like to know if it is possible to add an external mechanism to a station that is already created. I know how to do it from a completely new station, but I do not know how to add it to a station that is already configured.
Thank you
Thank you
Mechanisms are different types of graphic components with links and joints. F.e. tools, robots, external axes or conveyors. They can be created here: Modeling -> Mechanism -> ...Do you want to add a robot to the station? Then that is quite easy. Home -> Build station -> ABB LibraryIf you want to add a robot to an existing virtual controller, then that is a bit more difficult.
I have investigated a bit little about this issue and I have comprobated that is possible to add a mechanism on a station already created, but I dont know is the better way.
I acced at folder with *.cfg files on: C:\Program Files (x86)\ABB Industrial IT\Robotics IT\MediaPool\RobotWare_5.15.7005\utility\AdditionalAxis\General\DM1
from: Controller/Edit System/AddIs it the better way or are there other way more simple?This works.
