add to right click menu
                    scottMHA
                    Is it possible to add buttons to the right click menu below?
            Did you found a solution scottMHA?
 Unfortunately not so far, still on the hunt as and when time allows.SierraWhiskeyHotel said:Did you found a solution scottMHA?0
            UseCommandBarContextPopup ctxPopup = UIEnvironment.GetContextMenu(typeof(Part)); to access the menu.
 Post edited by Johannes Weiman onJohannes Weiman
 RobotStudio Team, ABB Robotics2
            Johannes Weiman said:UseCommandBarContextPopup ctxPopup = UIEnvironment.GetContextMenu(typeof(Part)); to access the menu.Thank you for the answer. Now that I found some time to try this I failed VS doesn't know Part in context of the typeof expression. Do you have a short simple example how I can add buttons with my custom code to different menues?My goal is to add a button to the menues of paths, robtargets and workobjects. If you could show me an example of one of them I would really thank you for that.0 VS doesn't know Part in context of the typeof expression. Do you have a short simple example how I can add buttons with my custom code to different menues?My goal is to add a button to the menues of paths, robtargets and workobjects. If you could show me an example of one of them I would really thank you for that.0
- 363 IRC5
- 80 OmniCore
- 853 RAPID Programming
- 31 AppStudio
