velocity and coordinate of a tool center point instantaneously
hyacy
Hello everyone, I would like to write a code to read the speed and coordinates of TCp instantaneously whyle moving and transmit it to my computer could you help me please. I will be really happy
Hi,if you have Option PC-Interface you can send to pc via socket. PC will be a socket-client , Robot will act as a socket server
Socketclose ComSocket;
SocketCreate ComSocket;
SocketConnect ComSocket, sPCIP, nPCPort \Time:=10;You define a time interrupt of 10ms and in the trap you read TCP and send the valus as formatet string to the socket like this:TRAP SendPos()
VAR pos tmppos;
tmppos:=CPos();
SocketSend ComSocket \Str:= NumToStr(tmppos.x,2)+ ";" + NumToStr(tmppos.y,2) + ";" + NumToStr(AOutput(aoTCPSpeed),2) + "!";
Delete intno1;
CONNECT intno1 WITH SendPos;
ITimer \Single, nIntervall, intno1;
ENDTRAPNote aoTCPSpeed must be declared as AnalogOut and linked to system-output "TCP-Speed"Alternativ you can install a fieldbus-communication card (like HILSCHER CIFX) in your pc.Good LuckDaniel
1 -
Thanks Daniel i will give you a feedback after trying it!0
hi!
i tryed this code but it ist not working . i dont really know how to work Robotstudio, so this is what i get and i dont really know how to continue
so may be i didn't explain the problem very well so, i have this robot on the picture below , and i just want to get the tcp_Speed (velocity)on anlalog output , while the robot is moving; could you please show me the way from the beginin? I'm really new on this . thanks
Hello,Is Signal Analyzer Online sufficient for you?☑️2024 - RobotStudio® User Group0
Hi Denis yes i just Need it on Signal analyer0
