Can't change system options
EricH
I get this error message from the output, when i try to change the options:
RobotStudio .NET exception:
OptionManager.OptionManagerException: Option "810-2 SafeMove" conflict with option "1125-1 SafeMove Basic 996-1 Safety Module " in the system
at OptionManager.RoboticsOption.RawSetOption(Option inputOption)
at ABB.Robotics.RIM.SettingsManager.RawSetOption(Option option)
Base exception: ProductSettingsException
at RobotStudio.Services.Systems.SystemBuilder.SystemBuilderGandalf.GetSettingsManager(ControllerSystem2 controllerSystem)
at RobotStudio.UI.Controller.GandalfOptions.GandalfOptionsDialog.CreateGandalfOptionsDialog(ControllerSystem2 controllerSystem, IEnumerable`1 hiddenGroups, Int32 numberOfRobots)
at RobotStudio.UI.Controller.GandalfOptions.GandalfOptionsDialog.<ShowDialog>d__10.MoveNext()
--- End of stack trace from previous location where exception was thrown ---
at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw()
at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task)
at RobotStudio.UI.Controller.Commands.ChangeSystemOptions.<OnExecuteAsync>d__0.MoveNext()
at RobotStudio.UI.Controller.Commands.ControllerCommandHandlerBaseAsync.<OnExecuteCommand>d__2.MoveNext()
at ABB.Robotics.RobotStudio.Environment.CommandBarButton.<RaiseExecuteCommand>d__49.MoveNext()
How can I fix it? I changed the system.xml and did a restart but it's still not working.OptionManager.OptionManagerException: Option "810-2 SafeMove" conflict with option "1125-1 SafeMove Basic 996-1 Safety Module " in the system
You cannot have option 810-2 SafeMove and option 1125-1 SafeMove Basic 996-1 Safety Module configured at the same time. They conflict. Remove one.0
I am trying. How can I do that manually? The window for changing the options is not popping up. Instead i get the error message.
Try using Installation Manager instead.Johannes Weiman
You cannot have the controller open in Robot Studio when you are trying to change options. Start RS new and open an empty station. Use Installation Manager to find where the Controller System is saved and change the options. In your empty station, from the Home tab, Open the Existing Robot System and I-Start it. The system will load with the new configuration.1
Thx, I think this works. Unfortunately the Installation Manager makes another copy of the system and the system in my station doesn't change.
- 363 IRC5
- 81 OmniCore
- 853 RAPID Programming
- 32 AppStudio
