IndAMove can't be used in module
Hi all, anyone know what is the reason of cannot use IndAmove (For example) in module?
i have read manual that it must be used use in main task T_ROB1. I wrote this instruction in Main() but not working too.
  • lemster68
    lemster68 ✭✭✭
    Do you have the independent axis option?
    Lee Justice
  • Hi Lemster, i found the independent axis option if i create a new robot system with customized option.
    If i create a new robot system without customized option, i would not able to choose options.
