Issues with RobotStudio 2019 - pack & Go - fails during unpack
experiencing issues around unpacking RobotStudio 2019
What is the error?Johannes Weiman
just states unpacking failed
I know one reason for this. Folder "RobotWare" in C:\Users\[user]\AppData\Local\ABB does not exist. If you have this case, then you need to create it manually, and reinstall robotwares that you need.0
- 367 IRC5
- 858 RAPID Programming
