error occurred when deactivate the force control
can anyone give some suggestions!
Thanks in advance!!!!
It looks like you have SafeMove setup?
Presuming you have setup SafeMove to stop/control hazardous behavior - you will need to modify your RAPID program so the tool does not violate the SafeMove parameters.
I did install the safemove. Could you be more specific?
It seems that the violation is because of the tool speed, however I did reduce the tcp speed by defining speeddata,
such as,
vmedium.v_tcp:=10;
Check the speed that you have set in SafeMove - this applies to both the TCP and the elbow of the robot, so you may need to slow the re-orientation speed in vmedium as well to control the elbow speed.
You also have a point on the tool going outside your safety zone (cause 11) on event 2.
Thank you so much. I am just a new starter to the ABB.
The limited speed in the SafeMove is 250mm/s and 18deg/s.
I set the speed in vmedium as following,vmedium1.v_tcp:=5; ! mm/svmedium1.v_ori:=5; ! deg/s
But it didn't work.
It is really weird that the rest of the code can be well implemented, just the robot cannot jump out of the force control.
The following are the parameters setting of the force control:Max Ref Force 1700Max Ref Force Change 1000Max Ref Torque 400Max Ref Torque Change 200Max Ref TCP Speed 0.08 m/sMax Ref Rot Speed 0.08 rad/sMax Ref TCP Acc 100Max Ref Rot Acc 100Lowest measured contact force 0Largest measured contact force 10000Lowest measured contact torque 0Largest measured contach torque 10000Speed superv. override 10Max Press TCP Speed 0.08 m/sMax Press Rot Speed 0.08 rad/skeep contact force at strop yes
Do these parameters make sense.??0 -
I am not an expert in the use of force control to be able to help much with a solution.
Does the robot ' jerk' when it disconnects?
You do not have any force controlled movements, though it appears you want to move down to contact a surface?
The force control manual gives some advice on force controlled pressure applications in the programming chapter.
Thanks a lot.
The robot doesn't jerk when it disconnects.
Just stops with the sound of motor turned off.
It is really weird that If I acknowledge the error, the command line "FCDeact;" can then be implemented without an error
and the robot will move to the point that i start the force control.
Yes, between the command lines
FCRefStop;FCDeact;
It seems that there is no obvious moving command.
But, like I mentioned before, if the command line "FCDeact;" can be implemented, the robot will move to the start point.
- 5.4K RobotStudio
- 383 UpFeed
- 14 Tutorials
- 12 RobotApps
- 291 PowerPacs
- 405 RobotStudio S4
- 247 ScreenMaker
- 2.7K Robot Controller
- 279 IRC5
- 46 OmniCore
- 3 RobotStudio AR Viewer
- 734 RAPID Programming
- 15 Wizard Easy Programming
- 105 Collaborative Robots
- 3 Job listings
