analog output in real value
hello! how can i get the real value of my  analog output , now my speed is 150mm/s but the analog output shows 0,15 , is the a way to get the exact value?
  • lemster68
    lemster68 ✭✭✭
    You must be using the system output for TCP speed, it is in Meters per second, so 0.15 would be correct.  You might play with the scaling, probably change max logical value.
    Lee Justice
  • thanks it worked
  • lemster68
    lemster68 ✭✭✭
    Great  :)
    Lee Justice
