analog output in real value
hyacy
hello! how can i get the real value of my analog output , now my speed is 150mm/s but the analog output shows 0,15 , is the a way to get the exact value?
You must be using the system output for TCP speed, it is in Meters per second, so 0.15 would be correct. You might play with the scaling, probably change max logical value.Lee Justice0
thanks it worked
Great
Lee Justice0
- 364 IRC5
- 82 OmniCore
- 853 RAPID Programming
- 35 AppStudio
