Create System from Layout Failure
DavidLanham
in UpFeed
I have found a bug with RobotStudio software Version 6.08.01 when I try and create a system from layout and I choose a folder for the system that has " ' " in the name like David's and try and create system it fails with a error.
Here is a link to a video that shows the error happening and then how I change the name and then it works.
It's a www.dropbox.com link
Thanks,
David
I have confirmed that this is a problem in RobotStudio 2019.2 as well
Thanks. This should be either fixed or blocked in the next release.
Johannes Weiman
RobotStudio Team, ABB Robotics0
- 365 IRC5
- 84 OmniCore
